Wipers ! Driving me mad !
The Badger
 Manchester U.K.
Has anyone suffered with this ! Wiper blades making a noise as if the windscreen isn't wet enough ! Even when it's peeing down arghhhh so annoying ? Just on the drivers side ?
go buy some BrunoX lube
Used for bike chains.
Spray the spring and other mechanicals.
Let it soak into the gaps.
Wipe excess and move on.
Worked for me, after changing wipers, rainX etc etc
Spray on the little moving parts on the wiper blades themselves too :thumbsup:
The linkage is just requiring some lube which worked for me. At least now they don't sound like they are trying to do an audition for "The Voice" :lol:
Ok guys is this something I can do myself ( I know nothing and I mean nothing about spanners and screwdrivers etc) and I may not gave explained it to well but to me it sounds like the wiper on the glass not the linkage ?
You could lift the wiper blade arms off the glass and then switch the wipers on, bet they will still make a noise. That way you will at least know linkage or glass
I had the same issue - annoyingly with new blades (the old ones were silent :headbang:)
For me Mer windscreen cleaner and a slight twist to the wiper arm worked a treat.
The blade needs to be at 90°to the screen in its starting position or as it drags back it makes a noise
Will go check now :D
https://www.youtube.com/watch?v=94Oxzt9m_QI
Have a look at this - good luck, I know how annoying it is :(
It's not the video I saw first time around (the technique in this one looks a bit brutal), but the message/theory was the same
It only took the very slightest twist to cure the problem and the Mers cleaner finished the job off
How old are the rubber blades do you know?
Have you tried cleaning the windscreen and wiper blades with meths to remove any film build up? Do the blades judder as they sweep the screen?
Possibly new blades might fix the problem if not, hope you get it sorted quickly
Have a look at this - good luck, I know how annoying it is :([/
YEAH ! That's it brilliant - looks a bit technical for me though .....involves mole grips ! LOL
I'll have a go at the weekend !
Thanks Obewon
Hi - see my edit above. I didn't fancy the mole grip approach either - did it by hand
My theory was that the old blades were silent, so it shouldn't take much (and it didn't)
Like Swifty said as well, make sure all is nice and clean - blades & screen
Blades were replaced by the dealer in the summer when I bought it - wasn't raining then lol :rofl:
The Badger said:
Ok it's definitely the wiper blade on the screen ! Not the linkage !
Hold on - despite your check it could still be the linkage - :o
The pressure exerted by the wiper arms is a factor of all the connections which brings about the pressure between the screen and the wiper - try lubricating all the parts mentioned (including all the small parts of the wiper itself) before buying new wipers - it's an easy fix and saves you money before moving on to new wipers - nothing lost and worth doing in any case. :D
Then if it doesn't work go for the renewal? :cry:
Good luck - we all know how annoying this can be!
:driving: :thumbsup:
Thanks everyone - will have a play with everything at the weekend
Soon to be squeak free Badger !
