Winter Zed plans..
True-Blue
Veteran
 Bristol/Bath
Post mainly aimed at uk owners, as we have a tendency to consider sorn’ing and ‘doing jobs’ in the wetter, darker, colder months.
I know many uk owners run their Zeds all year around, and I have before, but probably not this year with the Alpina.
My own car has had a fair bit of recent maintenance, so I think my main work with be a full ‘wheels off’ detail, with a gentle machine polish to remove marring and the current ceramic coating, followed by applying new ceramic coat.
I’m also considering a referb of the brake callipers . Everything works perfectly, but i fancy refinishing them and if I’m taking them off anyway it seems like a sensible precaution on 18 year old callipers.
Other than that, the car already has the only non-standard ‘mechanical’ modification I would consider in the B12 kit, and it was only fitted a few thousand miles ago with new top mounts etc. Then only other modifications I might consider relate to the audio, as my previous Si had a simple but very effective amp/speaker upgrade which made a big difference to sound quality.
So, what winter jobs, refurbs, upgrades have you got planned or are you considering?
Oil and filter change, de- rust the underneath and paint the callipers. Done the engine bay yesterday by removing the plastics and wiper area and using the vinyl and rubber care, and re-rusted the bolts everywhere. Now it looks like an engine bay and not a Scottish wreck.
Fitting the subwoofers and other upgrade bits I have bought.
Starter motor replacement as well.
Done the steering wheel spokes with alcohol as you suggested, so I now have perfect black spokes and bleeding fingers :lol:
I never sorn in the winter, but my Z4 will be sitting still a lot this winter while I do a lot of mechanical TLC. Here is my list at the moment (but it grows day by day):
  • Stud conversion kit
  • New wheels (when they finally get delivered)
  • Adjustable rear camber arms
  • Polybush all rear bushes (including diff bushes but not subframe to body bushes)
  • Replace driveshaft flex disc
  • Replace driveshaft center bearing
  • Replace CCV
  • Refurbish rear calipers
Its not in a bad way now, just want to get these done in the winter so come spring its in a lovely condition mechanically. :D
Some nice over-winter plans there!
I’d like to get front wheel bearings done. No issues with them, but passenger brake shield is rattling and driving me mad so thought it would be a good plan to do both at the same time.
Possible wheel refurb too as they have staining from somewhere which is impossible to shift :roll:
Other than that, just waiting for any dry, sunny day, for an opportunity to go out for a blast with heaters, heated seats and heated steering wheel on! :lol:
Ah yes, technically easy but physically a bit of pain in the….fingers, the steering wheel spokes :rofl:
I don’t usually SORN, but my tax and MOT ran out in September and I had planned a major brakes and suspension refresh, so I have decided to take my time and put her back on the road when ready.
New top mounts, dampers, control arms, hubs and knuckles (yes, a nice powder coated set to replace the rusty originals).
New discs, refurb/repain callipers and give everything else a good clean and de-rust.
Replace front bumper brackets
Oil level sensor and thermostat (both throwing up codes)
Maybe VANOS refresh
Flappy paddles now installed and working 👍
Put her to bed under dust covers for 6 months with the battery on trickle charge, once I have sorted the occasional eml light indicating an oxygen preparation problem . As it's a second car no point in paying the enormous road tax bill, my wife would probably divorce me if she knew what it was. And then I would have anyone to cook my dinner and iron my undies.
“Couple” of jobs for the winter:
Replace all bushings and upgrade to poly where appropriate
Refurb diff subframe, diff and axles, and fit LSD
Refurb front subframe, replace control arms
Replace engine and box mounts
Convert to hydraulic PAS
Refurb struts and fit new mounts
Preventive maintenance hot side engine
Replace gaskets and cooling system
Build headlights and replace current ones
Fit new seats
Build bespoke dash solution for screen
Plenty of stuff to do, the first half is a must, the second nice to have :thumbsup:
1. Remove and weld up cracked exhaust manifold
2. Refurb Alloys (unsure whether to go for Bronze or bright silver)
3. New Tyres (Trying out Yoko AD09s!)
4. general clean / spruce up ahead of Spring
Restore seats, detail interior, new coil packs n plugs , possibly replacing the Disa valve :thumbsup:
1536Z4 said:
I have been thinking about doing this myself . Which kit are you going with ?
I bought studs and nuts from PCD Parts. They seem good quality, but I am yet to install them as I have been away. When placing the order I only bought 16 nuts because I ordered a set of 4 open ended locking wheel nuts from Orranje Performance.
Below are the specs for everything I went with:
  • M12x1.5 Screw-In Stud 68mm (Black)
  • M12x1.5 60° Taper 19mm Hex Head Open Nut (Black)
  • Open Ended Locking Wheel Nuts (R53) M12x1.5 (Black)
  • Loctite 270
pvr said:
Getting ready today as the weather is appalling
Jeez! You are going to need Semtex to get me back out of your garage! :rofl:
I think in Czech Republic is now snow....and is like same in UK and with Z4 i cant drive now ....and now, is the Time for improvement :)
And now Z4 stay in garage and i do the improvement :)
Ele steering to repair - Erorr 0100
New Logo BMW
and now all for rear side brakes, caliper, coils, sparg plugs and many others.
Exhuast
Coils and sparg plugs
New front bumper
New painting - on goinig
New grill
New steering wheel shift paddles and multif. New 7" LCD radio aftermarket
New breaks done with new Calipers fot both side also hand brake
