Stuartt said:It’s a sad day when the winters go on
Stuart
Pbondar said:Is yours a pre or post facelift version?
Smartbear said:Pbondar said:Is yours a pre or post facelift version?
Is it the pressure sensors that make you ask? I bought the wheels with the sensors already fitted but my car doesn’t need them (uses the abs sensor & reluctor rings) :?
Smartbear said:enuff_zed said:You've probably mentioned it before, but what paint did you use on the hubs?
Sprayed or brushed?
Lidl metal paint, brush painted on. I’ve used it for a few years now with no issues with the heat![]()
enuff_zed said:Smartbear said:Pbondar said:Is yours a pre or post facelift version?
Really? Mine is post facelift but uses the TPMS sensors. It's a 64, so did they change that later?
enuff_zed said:Smartbear said:enuff_zed said:You've probably mentioned it before, but what paint did you use on the hubs?
Sprayed or brushed?
Thanks Rob,
Did you use a Lidl brush...............or a big one :wink:
Smartbear said:enuff_zed said:Smartbear said:Is it the pressure sensors that make you ask? I bought the wheels with the sensors already fitted but my car doesn’t need them (uses the abs sensor & reluctor rings) :?
I think the changeover was in 2014 sometime? :?
