I'm trying to find a picture and/or diagram that shows where the washer pipe to the underside of the bonnet is supposed to be routed.
On our 2014 E89 2.0 it is clipped to the back of the top of the washer bottle (in the grove) after it leaves the pump then goes to the back of the bonnet via a small cut-out in the sound proofing. It extends when the bonnet is open but on closing it has been getting caught between the rubber seal along the back of the engine bay and the bonnet. I have to guide the pipe whilst closing the bonnet so it drops in to the gap at the back of the engine bay. The pipe is quite stiff as there is a cable taped to it which I assume is for heating the washers.
I want to fully remove the washer bottle at some point to clean it and pump filters as there is gunk coming out of the jets and the passenger side is a bit weak at the moment. When I put it back together I would also like to fix the pipe/seal trapping issue. I'm not convinced how it is at the moment is correct.
Thanks for any tips and pics.
