OK, so this morning lowered drivers window just get some crisp cold air, come to close, stuck down.
No panic, have had a few occasions when it got stuck, just thump the arm rest next to switches will cure. Not this time.
So stopped, tried all switches, no movement from any window.
So operated roof just enough to drop remaining windows, windows lowered.
You have guessed right, come to raise, all stuck down.
So drove to work, bit nippy but I survived.
So pulled the door card off.
The connector plug to the switch pack is loose. It will push further in by 1mm. The windows operate normally. Plug out 1mm all windows stop functioning.
Can't work out how the plug detaches from the switch socket to have a good look.
Except this is the cause of the hassle.
My last resort might be to glue the plug in the fully in position.
