Windows not dropping for door open
birdy_z4 said:
birdy_z4 said:
Zforbes said:
Something I haven't tried on a E89
My last car failed and I replaced it, the liner simply clipped in so prised out with trim tools. That was an audi though so might be completely different. Sorry I can't help.
Looks like wheel and inner lining removal from looking online
It may be a red herring but it did used to work before the issues, ordered second hand off eBay see how it goes
Well that’s was fun getting to the petrol lock
Wheel liner removed nope also needed to remove petrol cap too :-(
So installed unit unlocks fine, but did not lock
Swapped over to replacement and exactly same :-(
Voltage on open none when locking
Maybe looking like an issue with JBE or fuse box
:headbang: :headbang: :headbang: :headbang:
There is a clue there somewhere, must be related to the window drop
Zforbes said:
No need to remove handle just the lock barrel
It's held in with a screw hidden behind a rubber grommet in the door opening.
Take note how it fits together, a bit more fiddley than passenger side.
After months of head scratching finally fixed my 9CBC window drop issue :roll: :roll:
Fuses checked
FRM checked ( second hand one registered, same issue)
Door wire consistency for breaks checked on driver and passenger (and rechecked)
Fuse box out completely and all connections checked
Door locks changed drivers and passenger
Still had the issue
Jbl out, second hand registered still same issue
So thought that the FRM had switched off power due to short circuit
Lots of online research also got a reading from dr.gini that showed faults where originally in door contacts but now fixed
Found a post that suggested to try the below
Problem solved:
the
SNU_TK_ABFRAGE_OHNE_PULSE = aktiv
needed to be:
SNU_TK_ABFRAGE_OHNE_PULSE = nicht_aktiv
Programmed the FRM with the change and it worked !
Windows now dropping and closing ……. :roll: 8) :D
Now I’ve just got to solve why my mirrors no longer fold in when locking the car or out when opening
Oh plus an MOT overdue
So was the original FRM faulty and the replacement FRM not from an e89?
Glad you got it sorted and nice of you to update with the fix, that’s what’s great about this forum
Blue Peter badge for perseverance :thumbsup:
And as Chippie says good to get the solution posted..
Fuses checked
Still had the issue
Problem solved:
the
needed to be:
Excellent news, as others have commented understanding the fix and posting the results :thumbsup:
I'm assuming someone's previously coded the mirrors to fold when locking?
Mine don't fold until I press the fold button, think that is standard.
Fuses checked
Still had the issue
Problem solved:
the
needed to be:
Mine used to fold but stopped so presume something in the FRM changed will let you know
