Windows 10 font size-
andysat
Hi all-since I have downloaded windows 10 quite often when I move the cursor around it decides to alter the size of the words-is there any way to 'lock' it at a certain font size?-thanks :)
stuartC said:
Could you post a screen shot ?
Sorry-not tech minded! :oops: -its just as I sweep the cursor around the screen-I goes from 100-125% , I have to keep going to the top right corner where the 3 dots are to bring the zoom down.
Is this on a laptop using a touchpad?
If so, you're probably activating the zoom function - depending on the touchpad it may be called 'pinch zoom' (for multi-touch touchpads) or 'swipe zoom' or something similar
Try going into the touchpad settings and disabling the feature
Yes and yes-thanks I did not know there was a touchpad setting? :oops:
