Window Wiper Relay location
spinnerhawk
New member
Hi,
I have recently bought a Z4 from 2003. I am struggling with finding the 2ea relays (see attachment) controlling the Wipers. I have searched behind the fuse rack under the clove compartment and in the relay box on the most left-hand side in the engine compartment. But cant find them.
Any tips for me guys?
I'm sure someone will help you but try posting in the other e86 e85 links might help. :thumbsup:
Not sure if you're LHD or RHD?
As far as I can tell though, they should both be on the back of the fusebox.
K36 and K37.
However, firstly, what is your problem? Sometimes grease gets onto the contacts in the motor so it doesn't work properly.
It is also possible that it is the GM5 module causing the issue.
Need more info to help you properly.
[ref]TOMGREEN413[/ref], since my previous post I have seen you post on many different threrads, but not answer me on this one.
I would appreciate it if you could please explain why you gave a thumbs down to my answer for the OP.
It makes it look like you are being sarcastic for some reason which I cannot fathom.
Many thanks. :thumbsup:
