BumpyZ4 said:The wiring for the pump motor is as simple as it gets, 1 ground wire to the chassis and 1 power wire to the GM5. We know the ground and the power wires are good as the pump works (although un-commanded). The stalk was a good guess as it provides the drivers wishes to the GM5. So I have a feeling that your GM5 is bad. If it was a shorted wire it wouldn't wait 10 minutes before it started pumping the fluid.
This is interesting and thanks for the diagram, reply and info.
Interestingly, I had the GM5 module serviced by a company on eBay (relays changed) after a central locking issue (stopped opening doors and the boot one at a time). The GM5 module was sent away, repaired and reinstalled which the fixed the CL issue and avoided a ~£400 replacement plus reprogramming a new one. The service I paid for was particular to central locking issues.
It'd be a little bit rubbish if there's another issue with the module and I may not have avoided the above costs, but your logic does look to add up to that being the case.
Or maybe in their work, is there a chance of a short being created on the board? Bit too generous with the solder? I didn't remove the circuit from the housing, but maybe I'll remove to inspect. I do love being in the z4 footwell :rofl:
Other info, not sure if relevant but I have headlight washers too, this hasnt fired since the issue occured, not on any of the 20 or so occasions where the window washers have fired by themselves.
I appreciate your thoughts.
Steve
