Window switch ?
road warrior
 Burton On trent
My drivers window works OK but I have to hold the switch when I want to close it, down it's fine, just up.. Is it the switch?
That's how they are RW. Mine's the same :thumbsup: Whilst you're on can you and Tug check your emails ta ? :wink:
Do you mean your 'one touch' function only works in the down direction but not in the up direction?
Have you tried resetting the 'window ends' (excuse the non-technical term). Get in the car. Turn the key till you can operate windows. Close the door. Hold switch to open the windows till it reaches bottom end. Then Hold switch to close the windows till it reaches top end. Repeat this process a total of 3 times. This should train your window and re-enable the one-touch function for both ends. One-touch only works while the door is close.
correct :thumbsup:
I will try today
Not quite as the window on the left goes up and down when the roof is used but the right only goes down but does not return on its own
I have a similar problem. Drivers side works as it should, but passenger side only works with ‘one touch’ going down. I need to hold the switch to bring it up again. Tried re-setting the window numerous times, but to no avail.
In addition to the above, the passenger window refuses to drop the usual small amount when opening the door. A few goes at operating passenger window from the drivers side switch and it seems to sort itself out, for a while. Then the problem returns.
i am the same but nothing works for me so far.. even short term..
well bugger me.. it worked !
i did the 3 up and and down trick - and its worked.. AND it now closes the window when i drop the roof - bloody wonderful ! thank you gentleman, now if i can get rid of this bloody airbag light ............ :headbang:
