WINDOW PROBLEM ? DOESNT DROP !
easty027
 South Manchester & East Yorkshire
Could anyone shed some light on the problem I am having with my passenger window ?......when opening or shutting the door the window doesn’t go up or down to form the seal as it should. Its as if its positioned to go up when you close the door, however It stays in the same position leaving a very small gap between the hood and the window edge.
Is there something I need to do to reset the thing ?....the window operates perfectly well apart from the seal problem (i.e. goes up & down with no problems).
Thanks in advance. :thumbsup:
minde does it every once in a while, but I never reset, the next time it's always OK
however you may want to try http://www.z4-forum.com/forum/viewtopic.php?t=190
