Window mechanism
domsz4
Veteran
Anyone know where to buy a vapour shield and window mechanism from?
Found a mechanism on eBay. But not the vapour shield. Can these be repaired?
skelters said:
If it's not torn then you can probably reuse it.
You may get the part number on here.... https://www.realoem.com/
If not try giving a local dealer a call if there's any open anywhere!
You'll also need Butyl tape.
you'll need to be sitting down too when you get the price. I ordered a pair from my stealer and if I remember rightly they were £68 for two bits of foam ! :o :o
Jesus Christ. In the most it’s on just one corner was been on and off a few too many times.
The mechanism is goosed too. Looks like a cable has rusted, jammed the wheel on the motor and snapped the cable/a bit of its plastic cover.
I was £358 for BMW in Glasgow to replace the lot.
£68 isn't a bad price really if you're doing it yourself.
