Window help required!!!
paddy wright
Elite
 south yorkshire
Site Supporter
Dropped roof for a run home but passenger window didnt drop! Switch makes a click but no movement! I'm about to drive to manchester and need to know what to do! Roof up and leave well alone?
could be the regulator, which is about £100 for the part.
When you open/close the door does it drop slightly?
Exact same thing here Paddy,but mine is the driver window.it comes down a tiny bit but that's it,is this covered under warranty? Sorry but as I have the same problem,thought would be best to share.
Window doesn't even drop when door opens! Thought it may have been the regulator- how do I do the window reset? Just in case it's only that?
This is the window rest.......
1. Turn on the ignition
2. Depress the individual window button until the window is open, then keep it pressed for 5 seconds longer.
3. Depress the window button until it is closed, then release.
4. This should reset the memory on the window.
Same procedure for both windows
BUT if the window is not working then perhaps a more serious issue.
after 2 weeks of waiting took to the car to the dealer this morning,they checked the window and the regulator was gone,but as they didn't have the part,will be fixed in 2 weeks time ! are they really that busy?although I did ask for a Wednesday appointment,but this is not the first time!
