window didn't go down
mystik
 i'm from the bay (california)
i noticed the strangest thing ever.....
i was putting my top up last night and the passenger's windown didn't go down like it normally would.
my driver's window was completely down and my passenger's window was completely up. i had to re-open the top midway through, raise my driver's window a bit, then i closed the top again and the passenger window went down like it normally would.
it's all sorted out now.. but it's just a little strange.
I had the opposite problem: In the last stage of closing the softtop the side windows first went up as they should but occasionally directly down again. Solution: You need to make a new indexation. Open the window by holding the switch all the way down and hold it there for at least 15 seconds. Close the window by holding the switch all the way up and hold it there for at least 15 seconds. Now a new indexation is made and hopefully you get rid of the problem.
