Hi everyone,
Recently picked up a 2004 Z4 2.5i roadster and I have a passenger window control issue.
When controlling the window from the driver’s control, the passenger window will only roll down, regardless of whether I hold the switch in the up or down position - window only goes down. Driver’s side window switch works correctly.
Passenger window responds correctly (i) when controlled from passenger side switch , (ii) when lowering or raising the top and when holding the open button on the key fob. Seems to only not work correctly when controlled from drivers side.
I purchased and installed a new driver’s side window switch panel from BMW and I tried the window reset steps. No luck - issue remains.
Where should I investigate next? Thanks.
