Swiftly said:Have you tried resetting the windows?
Turn the ignition on
Push the open window button until the window is open, then keep it presses for 5 seconds longer.
Push the close window button until it is closed, then release.
Do the same procedure for both windows, this should reset the memory.
Rene_Z4MC said:Tried that on the driver side only, that didn't work.
Will try it on both windows now, see if that makes a difference.
UPDATE: 'One click down' works again, up is still defective :?
srhutch said:As bing said resetting can be difficult. I I know I had trouble. Once the window is fully lowered/raised release the buttons and then press/pull again for a few seconds just to be sure.
Sim, changing the door shouldn't affect this although early cars did not have this feature on the passenger side. I would guess that's was controlled within a module though within the car not the door.
Wyldie85 said:Did you get this sorted at all? My windows did this. Got the drivers one working again but the passenger one still doesn't go back up on the 'one touch' or when closing the roof and holding the button. Very odd...
Same hereRene_Z4MC said:Wyldie85 said:Did you get this sorted at all? My windows did this. Got the drivers one working again but the passenger one still doesn't go back up on the 'one touch' or when closing the roof and holding the button. Very odd...
No still the same, tried resetting procedure a few times but no luck.
