When I studied Environmental Science we used to work out the environmental cost vs the energy benefit.
People seem to forget there is a huge energy cost to create these before they are beneficial. Digging ore, destroying forrest to get to said ore therefore creating more CO2 but less trees to recycle it, transporting ore half across the world, smelting and producing a high quality metal, transporting metal where its needed, fabrication of millions of components with most of the process above, create generators, keep the generator working with oil. Then transporting these wind turbines across the globe where they are needed then installing them with hundreds of tonnes of concrete again mined (most of our limestone is in our national parks) sent to where it is needed. They also have to have brakes installed because if the wind is too high they will destroy themselves.
So for the huge amount of global energy it takes to produce, transport and install a wind turbine VS the amount of energy they produce over their limited lifespan (25 years) the energy costs to keep them running, lubrication etc. They produce less energy over their lifetime than the energy cost to produce and keep them running.
Also bare in mind that they can only be used in a limited speed, and the amount of time it takes in a good speed of wind to produce anywhere near the amount of energy needed they become fairly pointless. There are better, less energy consuming green solutions than wind turbines. One wind turbine working for full day at maximum efficiency will produce enough energy to light 350 homes if the wind is at exactly 28 mph all day If the wind reduces to 14 mph that number drops to 35 homes If the wind drops to 13 mph that number is 20 homes. The likelihood of having a day like that is near enough impossible.
Obviously the above info depends where they are. But generally they aren't brilliant, until technology improves.
There a hundreds dotted around the valleys in Cumbria, am I against them in a visually/noise polluting way… No I think they are pretty cool but they need to get a lot better before they are a viable energy alternative.
