Will this fit an E86
Will this fit an E86?
I've got 27 on the rear with a 9.5 and 19" so you should have no problems with these on the rear. Not so sure about the front though.
I have a 44 on the front with 15mm spacers making an offset of 29 (with 8.5 and 19")
I'd imaging you would be OK! :thumbsup:
They would have considerable poke, and on SE spec suspension will make the arch gap look more noticable... With a 4x4 look :(
I actually went and put the rim on and it is sticking out quite a lot on the front arch. 5-10cm I'd say so no good on the front.
The rears are probably ok but didn't bother checking since the fronts stick out too much.
