D Davz Active member Wellington, Shropshire Aug 7, 2019 #1 Been offered a Whiteline 27mm Arb which is for the E46. There is less curve where the arb links bolt to the arb, will this work? All other dimensions are identical. Will it work with adjustable links? Any advice much appreciated.
L LittleZ4 Active member Aug 7, 2019 #2 It should be fine. I have an E46 27mm ARB on mine (off an m3 convertible). Fitted on without issue.
D Davz Active member Wellington, Shropshire Aug 9, 2019 #4 just to confirm that the whiteline 27mm arb for an e46 is a perfect fit on the e85, standard drop links are also the correct length.
