kerstien said:
Since most of my journeys are rather short I think I should stay with oem then for performance as they will probably not heat up
Kerstien
The warmest that I've ever got the rear tyres of my Z3MC with spirited driving on the road is 58 degs C, but with the same tyres (Falken 452s) at The Ring, I've had them at 80 degs C in similar ambient temperatures, because I've been able to properly use the tyres' slip angle on track.
kerstien said:
Just one last question...so wider tyres in the front have the same principle or would cornering be improved ? Is a square setup better than a staggered or is the only advantage that you can rotate tyres?
Most cars have a square set up, but presumably the Z4M has wider tyres to cope with the increased heat produced by putting 338hp through them for traction, whereas the fronts don't usually get as hot as the rears. Because the Z4M has wider rear tyres, it consequently has a wider rear track width than the front and using a square set up of the same wheel/tyres sizes F&R will reduce the difference in track widths. Some people suggest that this tends to reduce a tendency to understeer and I think that's the primary reason for using a square set up with the secondary benefit of being able to rotate tyres all round.
I've never tried a square set up with the Z3/Z4 MCs but I have tried using spacers on the fronts only, to reduce the difference in track width, but I didn't like the handling: it made the handling seem a bit "numb". Perhaps this was due to the fact that I'd already got the cars handling neutrally with the suspension and geometry changes that I'd made.
