Wibbley wobbley!!!!! :/
markeg
Elite
 Lincolnshire Wolds
You had a hunter alignment done yet?
I've had wobble in the past, once due to a thrown balancing weight, once due to bush wear, and once due to alignment.
Tapatalking...
Could be anything. I'd start with simple of unbalanced wheel then move to buckled rim. After that I'd be looking for play in any part of the suspension, wheel bearings and alignment.
that will definitely be it, but i'm unsure why it would take 2 months for this to happen, unless you haven't driven at speed since.
I'd go for the buckled wheel. Balance can normally be driven through. buckled wheel just keeps wobbling and you cant drive through it.
Z4 wheels are easy to buckle, but you HAVE to look at the inner edge as this is where its weakest!
Ok, but when its on the wheel balancer, check the rim inner edge as its spinning.
Had a similar problem recently and found out it was due to my front tyres being warped, most likely from potholes.
+1 had this before. i had a bulge on the inside face of my tyre. caused horrible wobble.
