I've been fault finding my Z4 for a few days, it has had intermitted electrical faults which like so many others on the forum, I tracked to the airbag module between the seats. I fixed a broken connector pin on it and my electrics are now solid as a rock, sorted.
One thing was annoying me that the radio says "disabled", not a big deal but I wanted to see if I could check all the other cabling in the car to see if anything obvious could be causing it. I have checked all the other airbag modules and they are all clean with no water damage, but I did find this cable block which is located behind the passenger side rear storage hole. It has what looks like a data wire disconnected, so I plugged it back in, reconnected the battery and random electrical issues occured, no windows, no roof, lights on the dash cluster not appearing, airbag light on...and probably other stuff i missed. I pulled the wire back out of the block and the car is back to normal again..all good.
So can the hive mind of the forum tell me what the wire is for and why you think it might be affecting the electrics like it is? One thing to note is that I have the factory ipod module fitted and the fuse for the cd changer is removed, not sure if that makes any difference, the rest of the car is stock.
First picture shows the location of the block.
Second Picture is the wire in question
Third picture is the hole it should be in?
Fourth picture is the opposite side of the block.
