I was just making the suggestion that when you start involving pressure you can flow more but that doesn't mean it's not restrictive.pokeybritches said:Not sure what point you are making about an airline delivering 150 psi. I was providing a related example of how little the 3.5 inch housing restricts airflow- a 911 Turbo can move 700 horsepower worth of air with 1/6 the piping. This is mass flow, not just line pressure. By the way, I also use a 3.5” MAF housing to make the 700 horsepower, and the MAF sensor setup is draw through (non-pressurized side of the turbo compressor).RedUn said:Interesting response on zpost, what's the bypass valve diameter on a turbo car got to do with the intake on a naturally aspirated car? An airline can deliver 150psi but you wouldn't want to trade your mouth for one when going for a run would you?
Correct.Rombbb said:On the turbo analogy, I guess he meant that two 1 inch ports can allow for a lot of air / pressure, to emphasize that a 3,5 inch MAF housing isn't all that restrictive.
Any restriction through the MAF housing is minimal. I won’t say it’s non-existent, but it is so miniscule that differences in temperature and pressure will affect an alpha-n tune to a greater degree than the MAF will restrict horsepower. I have given multiple examples of how it is not a serious restriction, including cars that make 50 bhp more than the CSL using the stock airbox, Supersprint V1 stepped headers, Schrick cams, and a MAF-based tune. Z4Ms using MAF-based tunes can have a similar specific output to the 991.2 GT3 RS, even with 1000 less rpm to work with and an engine that’s 15 years older, built to a different price point, and still compromised for street use (other than no cats in the exhaust). Now let me ask a few of questions:RedUn said:Secondly MAFs are restrictive by design, have a look through one? Most High rpm high bhp per litre engines have no MAFs.
- How big are the S54’s intake runners in comparison to the MAF sensor housing?
- How many intake valves are open simultaneously, drawing air from the reservoir in the intake manifold?
- When air moves to fill a vacuum, such as the vacuum created when an intake valve opens and the piston moves down the cylinder, how fast do you think air moves to fill that void?
Tuning does provide other benefits besides increased horsepower, including mapping accelerator pedal sensitivity. You can have normal mode behave like sport mode, and turn sport mode into a sport plus mode. Or, you can go the opposite direction and make the throttle less touchy. SAP delete, rear O2 sensor delete, cat delete, etc. are all possibilities.Rombbb said:He is one of the few that tunes the z4m ECU instead of the easy Alpha N 'fix' (but still I prefer no tuning at all, not doing it for the HP's)
I wasn't saying the MAF is holding back the s54 either, I was just pointing out that by design, something like 30% of the surface area is plastic...hence a lot of high bhp/litre NA cars don't have them.
Sure you can tune with them, with cams, more compression etc etc you can still get good numbers it's just at some point (I'm not a mathematician) you'll need to open up the intake side more
