Why code a new battery
AnubisZed
Veteran
 Lincolnshire, UK
It often comes up as a question as to whether you need to code a new battery following replacement, well this little video explains it perfectly.....
https://www.dropbox.com/s/5wy4mv2thk1nt6v/330631791_139184989034461_1112747196044641860_n.mp4?dl=0
:thumbsup:
matsmith749 said:
Was excited to view this - but all I saw was some facebook knob dancing around with a scraper :(
Not sure, worked for ne, but I've changed the link now, so hopefully that'll work OK :thumbsup:
When registered my new battery with Foxwell reader, it only asked if i had changed the amp rating (no). After that i'm not sure it did anything else.
Just done mine - options with the autel 808 were quite a few.
Started with same type & capacity / same type different capacity / different type.
Then wanted to know if it was oem fit (code needed from the battery label if it was).
Other than that nice & easy.
Interestingly, it keeps a record of the battery changes with the mileage when it changed.
I remember now, yes same questions with Foxwell.
