whistling noise from engine.
ben g
Essex
sounds like it's coming onto boost (obviously not, but it's the same noise as i had in my focus st). can only hear it when the roofs down and i'm just cruising along with a light touch of the accelerator.
split pipe? or just a normal characteristic of the engine?
I get a whistling noise too! It's very noticeable under hard acceleration and mostly from 3.5-7k RPM. I don't mind it as it sounds like I have a turbo spooling up. :evil:
Ah, the old ghost whistle. Not unheard of... I have the same. Induction noise I put it down to
ah cool. no problems then :D
i do like the noise as it makes it sound like i have a turbo under the bonnet 8)
Hi
Mine does the same, it's like a turbo whistle when I set off, up to about 20 miles a hour
I've had 4 z4s now, all 3 ltr and this is the only one that has done it
It's the only auto I've had so don't know if it's something to do with that ???
Has anyone of you performed a hand over hand check of the rubber intake hose?
This noise seems to crop up when there is a crack or spit in the hose which is a common issue on older engines. I had the same issue on the Roadster. Inspected the hose, found a crack. Replaced hose, whistle noise gone.
Normally the crack seems to be mainly on the smaller section of the intake hose.
Just something to check.
i'd concur with Shipkiller - in my experience its more likely to be an induction leak somewhere...doesn't need turbo to exaggerate it, had same thing on a VTEC engine with leaky manifold....
