Which pilot bearing to install?
Tuna!
Ordered the exact same kit by LUK Schaeffler LuK RepSet 03-047 Clutch Kit from Amazon and got 2 completely different pilot bearings. 2 Different alignment tools and different notching in each kite pressure plate/clutch disc.
I have seen both styles of pilot bearings listed in parts for my car a 2003 Z4 2.5i with a Getrag 250 5 speed manual.
What is the difference between the 2? Has anyone switched styles? Which style is OEM?
lHmvvVh
If image doesnt work (always have trouble with this site. Here is the link to photo.
https://imgur.com/a/lHmvvVh
So with a little research I found out that one is a pilot bushing and the other is a bearing.
I like the idea of the bearing having less friction,chatter, vibration and offering smoother shifts. I dont like the idea that a failed pilot bearing can damage the input shaft.
Does anyone know which is OEM?
Does anyone else use a bearing or bushing?
The lack of replies is likely because I’ve never known anyone to change the pilot bearing as part of a routine clutch change!
Really? It comes with clutch replacement kit
I guess if you are changing the flywheel as well then? A clutch kit is usually pressure plate, friction plate and release bearing, I've never seen one come with the pilot bearing before :-)
