Hey guys,
I've got a "misfire on Cylinder 6 (P306) that comes up if i leave the car to idle when cold. If i drive away immediately from starting, it never comes up, and if i reset the code using an ODB2 reader then it goes away and doesn't come back unless i leave the car idling for >30 seconds when cold.
The car is also not perfect even when warm, big flat spot around 1800rpm etc and sounds a little rough.
I change the coil pack on what i thought was the 6 cylinder, and the car DID seem a lot better after, but a week later it's as bad as ever if not worse! Which one is cylinder 6? I have taken it to be the one closest to "firewall"...is this right? If not, it may have been just placebo! I have an m54b30 engined 2003 Z4 3.0i
Any help is appreciated.
Thanks,
Tom.
Thanks,
Tom.
