Where is this grease leaking from!
Viren
Noticed this yesterday while under the car, there appears to be some grease leaking (see link for picture);
Its on both sides (as in right and left in equivalent places) and the grease is thick (not runny). Its just in front of the rear wheels, if you looked just in front of the rear arches you would see this.
Any help would be appreciated!
FYI there are more pictures, just click on the picture.
At the Wales meet in April most if not all the ///M's put on the ramps had some weeping on the diff. Think most were the output seals though and a very light smear. Tech said it was perfectly normal.
Hard to see from that photo, but that looks quite fresh so might need some attention.
Turned out to be a rear cv joint (prop shaft) leaking. £5 seal and couple hours of labour and now all sorted.
