He posted on this page, the 12th post: http://www.z4-forum.com/forum/viewtopic.php?f=3&t=7&st=0&sk=t&sd=a
But none of the pictures show:
Does anyone have it saved?
First make sure the top latches in the stowed position. If you can lift it, it is not locked.
On the above pic, you also see the hooks. Make sure to grease these with some teflon spray.
If you top folds down this way, that might be the reason why it doesn't latch:
must be something like this, just push the fold:
Official service bulletin: http://www.bmwtis.net/tsb/bulletins/bul ... 40302g.htm
IF the top latches OK, then put some felt on the lock mechanism. You can see it clearly if you look through the rear window. ONLY ON PRE-FACELIFT models!!
THEN, remove the plastic cover for the manual top release (just above the center console) and put some felt in there or use some teflon spray.
PS: on the facelifted models, the lock is gone:
