Wheels sits askew, normal or not?
Yeddheng
 in the clouds
:driving:
I’ve just installed a set of KW V3 and GC camber plates.
4-wheel alignment was done with moderate settings (front camber -2,1, total toe 0,10) and everything looks good.
I’m very happy with the result but there is one oddity I have to check with you guys. The front wheels look like they are positioned unevenly, and when measuring you see that the right wheel sits about 7 mm more inwards than the left at the spindle. My front wheels, Arc-8, have the same ET (38).
Have you guys seen this on your Z4M:s, ie this is normal?
If not, is there some way to adjust it?
(I’ve had the car since 2008 and it has never been in an accident.)
You can’t change the camber on these cars so the only thing that I can think of it that the rear control arm Bush is either not seated properly (pushes all the way in) or it is knackered.
He’s concerned about the front wheels
Sorry, I may not had been cleaned. I was referring to the large lollipop bush that’s sits at the rear of the control arm/wishbone
Ah, ok. The OP has camber plates so can adjust the camber, but it could be the bush too.
My KW camber plates are set to different positions by about one graduation (on the scale etched onto their top surfaces) when comparing left with right, but the actual measured camber is the same side to side.
BMWZ4MC said:
:worthless:
Here ya go! :D
First a picture for comparison left and right:
...and some details...
Yes, that is possible if the lollipop is totally shot. The pivot angle could make the spindle at the other end move in or out. Whe inspected all the bushes including this and they all looked fine. But you never know.
But would'nt you feel it when driving, or even when pulling the wheel with your hand? And can you really make an alignment if that bushing is so bad?
MrPT said:
What’s your reference point for the measurements?
We meassured the difference between the same point at the strut to the brake disc.
Its also visible when looking at it, se picture above.
Maybe its the more aggressive camber that make it visible? I have not noticed it before
Aha, my GC-plates looks exactly like this to, and the camber is the same! I belive we are on to something here. If both camber plates is installed at the exact same place in the strut tower then there must be some difference below at the spindle. To make up for that difference you have to set the camber plates at different positions.
Maybe our cars are built like this? My mechanic could name some car models that are very different from side to side and are built that way.
Get someone to sit in the drivers seat and have a look, if it's been corner weighted they don't sit right without the weight in there :thumbsup:
Ok, thanks, I’ll try that. It is corner weighted but it was already perfect so we did’nt have to change anything.
I just want to add that this kit from KW is fantastic!
Wonky wheels or not, I could not hope for better handling and the rear is perfectly tamed and under control.
As they say, - totally epic! :thumbsup:
Mine are pretty even, I can tell as it's worn through the arch liners a similar amount each side! :evil: :rofl:
Hi, how are you getting on with them?
which ones did you get?
how far have you traveled? are they noisy?
also, question for everyone: do you know fixed, non-adjustable, camber plates for the M? I found them only for the others.
Thank you
Hi!
Everything works well thank you.
I have only rolled 1000 miles (1500 km) after installation and they are completely silent.
I have the street version.
I dont know about any fixed plates but you can shim the strut and spindle to get more neg camber. Search for ”E36 camber shims”.
