Wheels 295 18"
sylfe
 France
Hello
im searching for 18" wheels, i would like to know if the 295 wheels from z4 35is fit well the e85 ??? looking nice on e85 ??
front 8x18 et29
rear 8.5x18 et40
also im hesitating with bbs lm, 224 from z4m, 108 but corrosion, te37 (but too expenseive)
Yes they will "fit " but fronts are on the max & if car is lowered could be rubbing at times depending on tyre sizes
Ok
so it's a bad idea *.*
think bbs lis better choice.
thank you
i will continue searching 18" ^^
sylfe said:
Ok
thank you
Generally you should look for et numbers around 40 / rears can go down to et30 but fronts id have the line drawn at et35 & ideally et 38 to et42 :thumbsup:
