Wheel Spacers, Stereo & springs for sale
ShaunKC
 West Yorkshire
For Collection I am based near Brighouse in West Yorkshire, between Huddersfield and Leeds.
4 x 20mm wheel spacers and extended bolts £50 plus P&P. _SOLD
I had these on my last coupe with 18'' MV2 wheels and standard suspension. I originally only realised I needed them when someone on this forum pointed out how far the wheels sit under the arches, once I looked down the length of the car I had to have spacers, I'm sure you will too!
These massively improved the look of the car, bringing the wheels out to the arches, without any catching or rubbing. If you are running these wheels without spacers then you need to buy these off me, they are a no brainer mod!!
I'm sure they will improve the look and stance of your car on other wheels, I just haven't seen them on anything but MV2's.
I only had them on the car for 6 weeks; there is no rust or damage, the gold you can see is grease that I applied to stop them sticking when swopping wheels.
Front and Rear Springs off an M Coupe £40 plus P&P_SOLD
I think these have done around 25k, but I can't be sure, certainly less than 30k. The fronts look in good condition; the rears have some rust, which I have shown in the pictures. These are quite heavy and I think they may cost a bit to send, so collection would be ideal.
Pioneer Stereo, Fascia and connection kit for M Coupe £40 + P&P
This sounded good in the car, better than the standard stereo, but personally, I prefer the look of the standard unit better and so I swopped it back. When I used it the radio wouldn't get a good signal, I can't imagine this was anything other than a bad aerial connection at the back, but I never investigated, and so I guess it could be something else, better to let you know though. Although it was not to my taste it did sit neatly into the dashboard and the buttons on the steering wheel did work with it. Looking at the picture now, the user manual says Bluetooth, as far as I'm aware it doesn't have blue tooth, although it will take a USB.
Any questions please drop me a PM, I think the prices are fair but I'm sure someone will let me know if I'm miles out. 8)
Bugger , i have just ordered a pair of 20mm spacers+bolts literally minutes ago :x & i would also have taken the OEM springs but i'm pretty sure coupe springs are for coupes only :(
That's a shame, I nearly posted earlier too! I have no idea about the springs, I'm sure you know better than most.
bmwaddict said:
I'll take spacers if you can post :D
Posting is no problem, can you PM me your details and I will get a price tomorrow and let you know what it is. If you are happy with the cost I will get them sent out tomorrow. :D
Springs are the same for the coupe and the wendy house, it's the dampers that are different.
Are you 100% on that Tom :? previously with a Si roadster that needed a spring i was offered coupe ones from a forum member & my indy said that whilst they may technically fit there was a different compression rate between E86 & E85 ?
PM'd.
Hi, the headunit IS Bluetooth enabled...you can stream music from your phone and make/receive hands free calls.
A good buy for someone...especially with the loom for the Z4 included. :thumbsup: :thumbsup:
http://www.pioneer-car.eu/eur/products/mvh-350bt
Assuming realoem isn't lying, yes.
Looking closely at the picture the code is MVH-150UI, I don't think it's Bluetooth enabled, the link to the website is
http://www.pioneer-car.eu/eur/products/mvh-150ui
Shaun
