Just come across an interesting video about wheel sizes in relation to performance. I was thinking to go to 19” but I think now I will stick with my 18s
https://youtu.be/mPyg3ilw3KU
Silverstar said:Just come across an interesting video about wheel sizes in relation to performance. I was thinking to go to 19” but I think now I will stick with my 18s
Silverstar said:So the 17s would be best for road driving, except the really do look too small LOL. I know many here say even the 18s look too small on the Z but I think I will stick with the 18s, with normal tyres (non run flats) the car rides and handles just fine. Also I've only just recently spent 400 odd quid on the tyres :lol: Pbondar so are you still on 17s?
in the end that's what really matters mr wilks said:Enjoyable clip Silverstar but not sure how you reached the conclusion to stick with 18s over 19s :? Unless i missed something defining there was no outright winner in any of the 3 sizes to warrant someone changing from 19s to 18s or 17s to 19s :?
In the guys summary he mirrors my own thoughts on the subject in that the end user will find more noticeable difference between tyre brands / specs than he would from changing between sizes 17 - 18 -19 but using the same brand tyre .
In short if you choose the right size rubber & right brand manufacturer you can enjoy a 19inch wheel on any Z4 without compromising in any department .
In all the tests in the above clip the actual margins were down to a second & that was thrashing a hot hatch around a track .
Lastly as with most tyre reviews , they would be far more relevant if carried out on the same vehicle you were intending to fit the tyres to as a fwd turbo charged hot hatch is unlikely to handle anything like a rwd 2 seater na E89 E85 E86
Ultimately its down to personal preference which size wheels & which brand tyres the end user prefersin the end that's what really matters
Silverstar said:mr wilks said:Enjoyable clip Silverstar but not sure how you reached the conclusion to stick with 18s over 19s :? Unless i missed something defining there was no outright winner in any of the 3 sizes to warrant someone changing from 19s to 18s or 17s to 19s :?
I've got 18" with Goodyear F1 Asymetric 3 on and am happy with the ride comfort / noise and handling they give. I was thinking at some point in the future to change up to 19"s for the looks! (when my new tyres have worn out lol!) but I don't want to loose too much of the comfort that I have especially since I am also thinking to upgrade the suspension either just springs like Eibach or full kit like the Bilstein B12 which will firm up the ride a little anyway. Which tyres on a 19" rim would you suggest that wouldn't loose too much of the confort that I get from the 18s?
scootr said:I did a bunch of research on this before buying new tires and wheels. I decided to put 17 inch P4s on the E89 betting that the original engineering Plus better rubber would give me all I needed. The ride is lovely and it still bends a line so hard it can toss you against the door without sliding. I really need more side bolster.
mr wilks said:Silverstar said:mr wilks said:Enjoyable clip Silverstar but not sure how you reached the conclusion to stick with 18s over 19s :? Unless i missed something defining there was no outright winner in any of the 3 sizes to warrant someone changing from 19s to 18s or 17s to 19s :?
I think your Goodyears are already in the top 5 so brandwise no reason to switch , i'm guessing now the oe 18s you are running 255 35 18 rear / 225 40 18 front ?
Switch to 19s for example style 326s which from factory run 255 30 19 , no reason why you can't go 245 35 19 or 255 35 19 so zero loss of comfort , better rim protection & enhance the looks . the front 19s 225 35 19 on 8j id leave as is though you could go 235 .
Its only Bmw that run the skimpy tyres ( Audi VW Mercedes all run bigger on same sized rims) though it seems they've finally seen sense & changed up on the G29 18s & 19s .
For comparison the 911 997 i have is on 19s , the front wheels are 8j same as style 326 but oe tyre size is 235 35 19 , plenty of comfort plenty wheel protection .
As the vid clip highlights , you can't just say one size is better than the others , there are way to many defining factors that need considering![]()
