Wheel bolts - Where to source?
Easty-5
Aberdeen
I need to get myself some new wheels bolts (x16) as mine are a bit tatty. Where's the best place to purchase them from. I don't want some cheap and nasty ones.
Car is an M if the makes any difference.
Why not just remove a few at a time, mask the thread by pushing them through card and spray thebheads with aerosol paint? Costs virtually nothing and you keep OEM spec bolts.
I did think of doing this but will the paint not just chip and flake off after putting them back on?
cj10jeeper said:
At £11 for 16 bolts you'll get what you paid for.
Care to shed a bit more light on your statement?
My old mans just had all his bolts replaced under warranty on his 2010 1 Series Coupe, because there rusting. OEM can't be that great?
More than likely, probably when you put a socket over them. You could minimise chances by using a hammerite metal paint as its more impact resistant and use a 6 sided socket so there's less play/slip when refitting.
Sure. True OEM quality bolts tested to the correct tensile strength are very expensive. Bolts turned out in high volume from usually Far East workshops and untested, often mis marked and sold to a price.
I'm sure they are fine on a city car, but would not want to them on an ///M and op did specify he wanted quality
