wheel bolt torque setting
jamesbond
 UK
Hello
Would any know the correct wheel bolt torque setting for a 35is ? 326 19inch alloys
does 88 ft lb sound right ?
regards
If they're 12mm bolts on the E89, which I think they are, BMW spec 120nm +/- 10nm
If they're 14mm bolts it's 140nm +/- 10nm
It's fairly easy to remember as, for the common wheel bolt sizes, BMW now tend to spec (Bolt Diameter x 10)Nm +/- 10Nm
As BMW only seem to use 12mm & 14mm bolts, you should be able to use 130Nm for any modern BMW and still be within spec
Very impressive Perry - still don't have the answer from that link though . . . . :P
Just thought you might know - I'll sort it. (How long has newtron metriquecal been used? Does it mean I need to get rid of my wooden foot rulers and my chain lengths. . . . . you'll be telling me that there are metriquecal shoe sizes next . . . . .there are, :o well I'll be :lol: )
You just need to update your speedo - not much use in having one calibrated in furlongs per fortnight any more.... :P
My speedo's calibrated to grains of sand and needs regular tuning . . . .sorry that's turning :D I up-dated when I couldn't rely on the sun hitting my dial when passing speed cameras. . . .
Using my Chinese abacus, mine and Steph's fingers and toes and a bit of guesstimation,
130nm = 95.88307940601 ft/lbs (roughly) so in my estimation, that'll be fairly tight as against the other f'in tight. . . . . :roll:
