Been thinking about this fault and how the vanos may give the fault codes listed..
Theoretically the vanos could cause the valve to held open due to incorrect valve timing... It could cause huge valve overlap time, not fully closing the valve correctly on the combustion stroke..
But... The car would have low power and probably a lumpy idle too ( assuming the vanos had locked the timing fully one way)..
It would also have plenty of timing and vanos fault codes to back up the rich running codes..
Let me know how you go, and if possible how the tech has determined that the vanos is at fault..
I have heard of the vanos going faulty after a car has been stood for a while, but usually they are very reliable.. The drive breaking or the loose bolts fault they have wouldn't really twig the EML for rich running codes either..
