Hello again everyone
I have noticed a slight vibration when braking, upon inspection I have found my front discs are slightly warped, as you turn the hub (wheel off) there’s a tight spot on each revolution and you can clearly see a good millimetre maybe more of gap change between the disc and pad face as it rotates.
so I am pretty confident this is giving my braking vibration. Anyone know What causes this to happen? Is it cheap discs? Calliper issues? Poor design? Now I wouldn’t say these cars are that heavy and having vented discs you wouldn’t think heat would cause it???
I am now looking to order new discs and pads, is there a recommended solution out there, ie drilled vented discs?? Or a particular brand to go for…or avoid. Should I be checking anything on the callipers? Or even the rear brakes? The discs fitted have plenty of thickness left on them and it has previously been serviced by BMW so I guess they are supposedly genuine ones fitted.
Any advice much appreciated as ever
