B21
I've bought an Audiotec Fischer Match UP 10 DSP digital amp and DSP tp replace the 677 Top Fi set up in the 35is..
https://www.audiotec-fischer.de/en/match/amplifiers/up-10dsp
I bought the SDM125 box that allows the fibre optic signal with the audio information from the head unit to be decoded and fed to the DSP/amp
https://www.audiotec-fischer.de/en/helix/accessories/sdmi25
Amongst many other bits I bought a specific BMW to Match 1p cable adapter.
Given the confusing and overlapping nomenclature over names for various speaker positions I was suspicous that yet again, like the 676 Hi-FI version and the Match 7 that was 'plug n play' that it wouldn't all work out perfectly.
So I sat down today for about 5 hours to try and see if the custom cable matched and which amp channel (there are 10)on the DSP was powering what speaker..
Super colour coded spreadsheet later..plus multi meter..
So bottomed it out..as I suspected close but not exact.. most of the audio out of the orginal 677 amp goes via a 20 pin connector.
BUT..the rear centre channel between the seats at head height for reasons only known to BMW comes out on another connector whose primary job is to supply power to the amp.
Quite why oh why they did this when there are two spare connector pins going begging on the 20 way connector god only knows.
I guess, yet again, on the E89 they bodged and existing design to save costs.
AF obviously lost the will to do something about it as the 10 channel amp has one spare channel which would marry nicely with the missing rear centre channel..but they just didn't bother..
I'll work a way to patch that channel across to that connector.
It wll have to wait till the spring / summer when I finish building my garage and then can take the back end of the car apart in the warm and dry..all first world problems..
What did you do today?
