Russ59 said:
What I don’t get, is that I’v often just rinsed the dust of the car and left it to dry, but it’s never left marks like this before.
You said in your original post that you had recently treated your soft top, correct? Had you only used the cleaner or had you also used the sealer?
The reason I ask is when I messed up the Z3's paint I had rinsed off the cleaner and let it dry in the sun. Big mistake. I'm thinking that if you had recently used a soft top cleaner...maybe the top still had enough cleaner in it that rinsing the car released that and you got the spotting similar to what I had...Just a guess.
I tried just using wax by hand and a few other products as I recall (it has been awhile). I did use a PoorBoy product eventually but I don't recall what exact product or what color buffing pad I applied it with.
However I did claybar the car first, and whatever PoorBoy compound I used I applied it with a Flex orbital polisher...I don't think you will have satisfactory results using the compound hand applied only. There are less expensive orbital polishers out there other than the Flex but I think you'll either have to go that way or have a pro do a paint correction detail for you.
I would also investigate that acid product I eluded to. I heard about that in a YT vid done by a pro detailer. He did not give any product name but he did say it was an acid and it was used for removing water spotting. It may be one of those products you can't get unless you are in the business..??
Good luck, let us know what eventually worked for you.
