mr wilks said:For me nothing on the front , the rear i would add 10mm/12mm or 15mm .
It will enhance the stance measurably .
I always ran 9.5 et 35 rears on the 3 E89s i owned , sat & handled a treat plus filled out the arches without rub
To get the same rear fit you would need a 15mm spacer![]()
mr wilks said:That pic above shows the E89 "problem" off perfectly , the rear wheel track looks narrower than the frontnot a good look imo & as with the ZMs a wider rear stance looks far better which is why i switched all the previous wheelsets off & went for a wider rear track
enuff_zed said:mr wilks said:That pic above shows the E89 "problem" off perfectly , the rear wheel track looks narrower than the frontnot a good look imo & as with the ZMs a wider rear stance looks far better which is why i switched all the previous wheelsets off & went for a wider rear track
Agreed.
For a while I owned both a 2.8i Capri and a 1.6 Mk2.
Exactly the same issue with the wheels not filling the arches properly on the smaller model.
I like these wheels. Easy to keep clean, good looking (to me), and a relatively comfortable ride, which will improve shortly when I wave bye bye to the RFTs.
So I think then that I will start with a pair of 15mm spacers on the rear. Thank you.
Any recommendations on which to buy?
mr wilks said:enuff_zed said:mr wilks said:That pic above shows the E89 "problem" off perfectly , the rear wheel track looks narrower than the frontnot a good look imo & as with the ZMs a wider rear stance looks far better which is why i switched all the previous wheelsets off & went for a wider rear track
Agreed.
Ive used Mtec ones many times https://www.ebay.co.uk/itm/BMW-15MM-MTEC-HUBCENTRIC-ALLOY-WHEEL-SPACERS-FIT-BMW-E36-E46-E90-E91-E92-UK/372342920806?fits=Car+Make%3ABMW&hash=item56b15e1666:g:7uUAAOSwg6Nc~kaG on ebay around £35 with bolts , i wouldn't buy into the snobbery over buying spacers with big brand names , simply not necessary :roll:
enuff_zed said:Bit of a thread revival, as I still need some help.
I have decided to definitely fit 15mm spacers on the rear and leave the front as it is.
But............. all my wheel studs are black.
I can only find spacers with chrome/silver bolts.
My OCD wouldn't cope with different colours front and back, so what options do I have?
Covers? Replacement silver fronts? Or ideally, would prefer longer black bolts for the rears.
Oh, and to clarify further, I don't want black spacers either thank you.
Silverstar said:You could just put black covers on, probably the cheapest and quickest way.
I have question regarding the spacers I assume the same set up would work with the 294 model alloys? would 12 or 15mm spacers also work if the car is lowered on eibach or H&R springs? Also some say adding spacers can mess with the other components of the car like wheel bearings etc., what is the experience of those here that have spacers?
Smartbear said:Silverstar said:You could just put black covers on, probably the cheapest and quickest way.
I ran 15/12mm spacers on my 3.0si for a couple of years with no wheel bearing issues but it definitely made the car feel more twitchy, felt like it needed constant correction on motorways :?
enuff_zed said:Smartbear said:Silverstar said:You could just put black covers on, probably the cheapest and quickest way.
Thanks Rob, worth bearing in mind as its purely the looks I'm after.............................. so is it worth it?
scootr said:I put 18/10 on mine. Stock ride height and tire size. I've since removed the fronts due to a high speed vibration issue. And I'm happy now with just the rear 18s. The tire is only slightly outside of the body flair (2-3 mm) I like it. I thought I saw black and chrome lug bolts of various lengths on eBay. Search by thread and length.
