what service does my car need next??
nightyard
at 53k it had oil service
at 70k it had inspection 2,brake fluid,micro filter
at 88k it had inspection 2,micro filter,air cleaner element
mileage isn't precise.
what do I need next as im at 105k and almost needing a service.
looks like just an oil service as its last was an inspection 2
looks like brake fluid could do with being replaced also.
Strange that it had an inspection 2 instead of just an oil service at 88k. Next one would have been an Inspection 1, but it all seems out of order, so it looks like it's only an oil service.
At what mileage were each of these services done?
practically what I said above... It was a company car so no expense spared I guess as inspection 2 includes all of inspection 1 plus some more..I know I would rather get another inspection 2 done if I wasn't paying :D
so oil service and brake fluid change I've figured out...last brake fluid change was 05/07/2011 ( the car came with a vehicle maintenance summary 2 pages long)
Oil Service and probably a set of plugs wouldn't do any harm. I think they're usually done at Insp2 but your list from previous doesn't show them as being done.
hmmm they were done when the brake fluid was last done in 2011...how often should they be replaced?
Plugs will probably be OK then. If, as I suspect, they are done at every Insp 2, and usually you would run 13k - 15k between services then you'd expect plugs to be changed every 50k miles or so. Looks like yours have done 35k so good till next service.
