What plasti dip spray
kis
Veteran
 Surrey / West Sussex Boarder
Afternoon all,
I’m surprised myself but I can’t find any plasti dip type spray at home. So I’m looking to buy. This is just a small 400ml aerosol type.
I’ve had a quick browse and there are lots on the market. So basically which one should I buy?
Not too fussed on the brand so long as it’s a good quality product.
Anything out there you would recommend? Or alternatively anything in particular I should avoid?
Cheers :thumbsup:
Thanks Marlon, I was just about to get this... but are you sure its a plastic spray? :? Nothing on any of the listings I've viewed says it's peel-able / reversible / removable.
I had these two lined up before;
https://www.ebay.co.uk/itm/202092861308
https://www.ebay.co.uk/itm/162300365494
Well I know it peels off paintwork as I'm forever touching up my A pillars, not sure it will come off the plastic roll hoops as easily. Guess you should stick with the make that specifically says it peels off.
Halfords have a range of removable plastic sprays in store i think... might be worth popping into your local store for a quick look
Plastikote is not a peelable spray paint. Plastidip is.
Just buy the matt black one, if that's the colour you want.
The first of your 2 ebay links is the one I have used on grills and it does peal off.
Go with the first one. Plastic dip will peel off easily enough, just make sure you have enough layers otherwise apparently if it's too thin it can be a pain to peel.
