Hi all,
I have the Zed booked in for 2 weeks today, (earliest I could get it looked at if I wanted a courtesy car
) to investigate this blooming engine whine when cold. Its kinda irritating as fairly loud and IMHO not right. I've had a good listen when its making the noise and have ruled out, drive belt, pulleys, alternator, air con compressor as the whine is there with air con switched off. Definitely not transmission. The Whine increases and decreases with revs but hardly detectable once on the move. Anyways the noise seems to be coming from the nearside of the engine specifically around the area I've circled on the engine pic below. Does anyone know what that part is? I think the turbo is on the otherside lower down. As the engine warms up the noise slowly subsides and there is just a hint of whine at idle.
I've been doing a fair bit of googling and found a couple of road tests of the Z4 with the N20 engine where it mentions it does whine but that doesn't seem to be the case with most owners on here.
http://news.drive.com.au/drive/motor-news/driven-bmw-z4-fourcylinder-models-20111221-1p4kd.html
http://www.carsguide.com.au/news-and-reviews/car-reviews-road-tests/new_bmw_z4_review
I'm just trying to establish whether some engine whine is the norm on this engine and that mine just happens to be a bit more noisier. If thats the case the dealer may just say its normal
The zed is performing fine, no hesitation or problems, just noisy when cold
Cheers,
Tim.
) to investigate this blooming engine whine when cold. Its kinda irritating as fairly loud and IMHO not right. I've had a good listen when its making the noise and have ruled out, drive belt, pulleys, alternator, air con compressor as the whine is there with air con switched off. Definitely not transmission. The Whine increases and decreases with revs but hardly detectable once on the move. Anyways the noise seems to be coming from the nearside of the engine specifically around the area I've circled on the engine pic below. Does anyone know what that part is? I think the turbo is on the otherside lower down. As the engine warms up the noise slowly subsides and there is just a hint of whine at idle.I've been doing a fair bit of googling and found a couple of road tests of the Z4 with the N20 engine where it mentions it does whine but that doesn't seem to be the case with most owners on here.
Cheers,
Tim.
