What is the "test" sub menu?
Matthew.
 Yorkshire
Hi, when holding down the button to reset the odometer, it brings up a "test" submenu. Then each time you press it the number goes up.
I've had a look in the handbook but can't find what this is.
Anyone know?
You can use it to reset the inspection/brake fluid change warning.
http://www.z4-forum.com/forum/viewtopic.php?f=25&t=22479
Other numbers are the test functions of the cluster itself. Somebody has described them in detail, but I can't find it right now.
Thanks for that. I did some reading up and apparently you can get the oil temp etc. displayed by going into the menus as well.
The full list of tests is here:
http://www.z4-forum.com/forum/viewtopic.php?f=34&t=15176&p=222820
