I’m sure my oil temperature gauge used to reach 10/11 o clock so I thought I would plug in my OBD2 ELM widget and dashcommand to see what was happening. From cold the coolant warmed up to 70c fairly quickly but then on dashcommand took quite a long time to get to 80c. This seemed fairly low to me but I haven’t anything to compare to. The temp would rise a few degrees when stopped but dropped to 78 ish on 70mph cruise.
I then did the test function on the dashboard ‘secret menu’ and test 7.0 reported 87/88c whilst dash command app was reading ~80c via obd2 port, this seemed more reasonable. Not sure why the figures are different so may see if I can get a better tool to measure it on a laptop.
If anyone knows what the normal coolant temp should be and the thermostat opening temp that would be really helpful, maybe it’s become weak and passing coolant to the rad too early.
Does anyone know if the oil cooler has a thermostat too?
Cheers in advance.
Ad
Cheers in advance.
Ad
