The fun of dragging trolley jacks out at 7.15 this morning and hopefully not waking the neighbours, so I could get the front in the air, remove the undertray and replace the auxillary belt on mine, before the sun crept up the drive to incinerate any flesh it could find, currently that is 8am. Getting off wasn't too difficult , but with putting the torx in the tensioner, it undid the tensioner pulley when refitting :roll: . So, I put on the belt other than the a/c compressor and a ratchet strap around the crank pulley, water pump and pulled the tensioner down to be able to slip it into place. As to why I changed it, there seemed to be a mist of something oily on the outer edges of the belt. Not sure if the previous owner had sprayed belt anti squeal on it , as couldn't find any leak from anything or could have been slight contamination from the rocker cover job a while back. The oil filter housing is all dry. I did clean all the pulleys with brake cleaner to make sure it was all clean and also washed out the undertray, which had no oil showing, so a bit of a mystery. Oh and luckily the old belt kept its shape on how the new belt should go on. I did contemplate a photo before removal, but thought, nah, it will be fine :roll:
