Today I had the 5 parts to the strut brace powder-coated £25 cash it is now fitted
I finished off the routing of the brake hoses and the ABS sensor wires etc at the rear of the car.
Fitted the Petreson external oil pressure relief valve
Re fitted the trim in the wheel arches
Bled the rear brakes
Fitted the wheels
Turned the engine over to get oil pressure
Checked for oil leaks
Fitted the cam/rocker cover
Fitted the spark plugs and coil packs
Fitted the engine covers
Started the engine
Stopped the engine
Lowered the car to the ground
Drove it out of the garage
Power steering lumpy as a lumpy thing
Unpleasant noise from the engine bay this turned out to be the power steering after a few lock to locks and some more fluid it is all nice
Idled the engine for a short time turned it off to let the heat sink through
Run it a few more times to check and check and check all seams ok
Things left to do
A home 4 wheel alignment lazer line, string, steel rullers, digital angle finder, and set it up close as I can before a proper alignment. (Will keep the cost down as I will be charged by the hour)
Buy some new wheel spacers and fit them
Sort out my 1 series ABS issues
Tax it beginning of April and run in the rod bearings and then change the oil.
Start planing next winter maybe.........
Below a few pictures of the inside of my garage and yes I did all of this winters work in there on my own with 4 axle stands and a trolly jack not complaining it is just what I have.
