The octane rating is basically a measure of the resistance on engine knocking or of the anti knock properties of the fuel if you prefer it. The higher you go the higher the knock resistance. Unless you experience engine knocking there is not much difference between the 2 in terms of performance and fuel consumption. At the end of the day it is just 3 octanes more, i believe if you tried something around 89 RON which is available in US the difference will be more obvious. However the fuel in EU is of high octane rating anyway. I tried both and i got similar mpg with no visible change in performance. However the 98RON is a bit cleaner as a fuel. I might test them again now we brought up this topic
