got some recurring fault codes. what do they mean??
could any of them be explained by a bad battery as I just had to jump start it as it went flat whilst I was reading and clearing these errors :thumbsdown:
Motor Control:
Engine / Motor
Fehler: Lambda control bank 1 limit / Misfire Cyl. 7 cat-dam / Fuel trim bank 1 limit values / Lambda control bank 1 control block / Lambda regulator limit bank 1
Code: 00CA
Fehler: Lambda regulation limit Bank2 / Lambda regulator limit bank 2 / Misfire Cyl. 8 Cat-dam / Fuel trim bank 2 limit values / Lambda control bank 2 control block / Zuendkreisueberwachung (shunt voltage measurement) OBDII fault!
Code: 00CB
ABS / DSC / Brake:
Airbag:
Airbag
ECU OK, no Fault Code
Transmission Control:
Transmission / Getriebe GS20
Instrument cluster:
Instrument cluster / Kombiinstrument
Light/Rain Control:
Light / Licht
Heating / AC:
Air Condition / Klimaanlage
Fehler: :Mixed air sensor 1
Code: 000A
Fehler: sorry, unknown fault
Code: 008E
Motor Control:
Engine / Motor
Code: 00CA
Code: 00CB
ABS / DSC / Brake:
Airbag:
Airbag
Instrument cluster:
Light/Rain Control:
Light / Licht
Heating / AC:
Code: 000A
Code: 008E
