what does detonation feel like? a thump and a thunk?
louis
 the exotic far east
hi guys,
would like to know if any of you could describe how engine knocking feels like when you're driving. is it purely a sound or can you actually feel it?
i was driving at about 50km/h in 5th gear(wrong gear.... i know...) and felt(and heard) a thump when trying to accelerate. my throttle was probably above 50% but i certainly was no where near being WOT.
it sounded like "thoooomp" and it felt as though i tapped on the brakes by accident.
i've had it happen a few times already, mostly in fifth gear, once in 4th, usually while attempting in-gear accleration from a low-ish speed.
does this sound like detonation to you?
Sorry mate, I'm not the most technical among us... Doesn't sound healthy at all though, would personally get it to a garage asap :o
I agree....usually the car will jump around like it is trying to stall if your gear is too high for the speed....get it checked :(
ran a OBD2 diagnostic check yesterday.
no faut codes relating to any cylinder misfires but i had several other fault codes including faulty DSC sensors, Hi-FI amplifier, rooftop control module.. etc etc
but i suppose the most likely culprit would be the fault code for a faulty crankshaft position sensor. a replacement has been ordered and will be fitted on tuesday, so hopefully that'll resolve my problems...
until then, i'm still curious what knocking would feel/sound like though.
cheers
Louis
you would hear the knocking.....but I doubt that you would feel it,maybe some lack of overall performance,but thats about it.sounds like the crankshaft position sensor will solve it.Had one go bad on one of my vehicles and it would stall or not start at all.that replacement will probably do the trick :thumbsup: :thumbsup:
